snahl
Apr 12, 2014Guide
RAIDiator 4.1.13 (sparc) OK for ReadyNAS X6 ?
Has anyone tried to upgrade an X6 with RAIDiator release (Sparc v4.1.12) or even the latest version (Sparc v4.1.13)? Which one is the last stable release of RAIDiator for the X6 ? Feedback is appr...
mdgm-ntgr
Apr 16, 2014NETGEAR Employee Retired
snahl wrote: ...YMMV What does that acronym mean (see previous post)?
Your Mileage May Vary. Or in other words it may not be the same for you.
snahl wrote:
Regarding the upgrade I might try it over the easter weekend and post the results here.
X6 is currently running on RAIDiator v. 4.1.8
Maybe it's a good idea to upgrade one by one following the release path.
No, one by one would not be a good idea. Would just use up more write cycles on the flash.
snahl wrote:
How about options to downgrade in case something goes wrong ?
As a last resort boot recovery is an option. But if tech support mode works this shouldn't be needed.
The firmware archive on ReadyNAS.com goes back much further than 4.1.6.
If you would benefit from the changes since 4.1.8 I would do the upgrade.
