eton
May 18, 2015Luminary
RAIDiator 4.1.14 changed bash shell behaviour - Bug?
RAIDiator version 4.1.14 changed bash's shell behaviour. Bug or new features? Example of executing bulkGetter script as user UserName under RAIDiator version 4.1.13 (Sparc): # su -c "bulkGetter....
eton
May 19, 2015Luminary
mdgm wrote: That script is not listed as executable. Also is the shell enabled for the User? By default ordinary users the bin is set to false.
Of curse it's listed as executable, -rwxr-xr-x (755). I wrote that I could run it under 4.1.13 and earlier as any user and that I can still run it as root. Or do you refer to something other type of listing?
Ah, you might have misunderstood my code example above. The file listed from ls is just a example of a downloaded file from the script, not the script it self.
