eton
May 18, 2015Luminary
RAIDiator 4.1.14 changed bash shell behaviour - Bug?
RAIDiator version 4.1.14 changed bash's shell behaviour. Bug or new features? Example of executing bulkGetter script as user UserName under RAIDiator version 4.1.13 (Sparc): # su -c "bulkGetter....
mdgm-ntgr
May 21, 2015NETGEAR Employee Retired
It's the same as it's always been. If the user you're su`ing
to has a .bashrc that redefines $PATH to include your chosen path, then
it will work. If not, $PATH will come from /etc/login.defs, which does
not, and has never (at least in the past 7 years, which is as far back
as I looked), included /usr/local/bin
