InteXX
Apr 05, 2016Luminary
Ransomware Protection Idea
It's all in the news lately and things are only going to get worse. Ransomware. But for ReadyNAS owners, I have an idea for a protection scheme. I'd like to get some feedback on its viability/rel...
- Apr 05, 2016
We don't recommend taking snapshots on iSCSI targets or using bit-rot protection with them (we link enabling/disabling bit-rot protection to enabling/disabling CoW) due to the fragmentation that can result.
However for ordinary SMB shares this idea could work well. You would need to allow space for the encrypted files (best to keep volume usage excluding snapshots under 50%) and you should have multiple copies of your data on multiple devices.CoW works better with some use cases than others. So if you are making a huge number of writes in place to files you are better to rely solely on backups rather than complement it with the use of snapshots.
Snapshots are useful for a range of things but I wouldn't rely on them as my sole defence against ransomware or other possible problems. There's no replacement for backing up your data. Backing up your data and using snapshots on both the primary and backup NAS can work well.
It's possible ransomware could evolve so that if it directly compromised a NAS (e.g. if you enabled SSH with password authentication and left the default password set) snapshots would be an ineffective defence. It's more likely that a Windows PC would be compromised e.g. due to a user opening an attachment they shouldn't.
