Sandshark
Aug 04, 2019Sensei
RD5200 and RN4200V2 fan control under OS6
I was looking throuugh the logs of my RD5200 converted to OS6 and found hundreds of entries such as this: Jul 31 01:15:53 RD5200A readynasd[6308]: failed setting new fan speed target: Permissi...
Retired_Member
Aug 04, 2019have you test 4200V2 sensors configuration in RD5200 in OS6?
#cp /etc/frontview/sensors/RN4200V2.conf /etc/sensors.d/system.conf
#systemctl restart readynasd
- SandsharkAug 05, 2019Sensei
After I moved the fans from the SAS backplane connectors to the motherboard, yes, I changed to the 4200V2 (same as 4200 and 3200) configuration file. It helped with everything but the fans. If the 4200V2 didn't share the same issue with the file location, I'd think I didn't do enough to make the switch. Could be I still didn't, though, if that is the right location for the files on the 4200V2. Unfortunately, the error message doesn't tell me where it's trying to write the information.
