SCUBAInstructor
Dec 04, 2019Guide
RDD516/RN516 case screws
I need a replacement for some ReadyNAS case/housing screws. What type of screws do I need? Best Regards Jochen
- Dec 04, 2019
The Chassis uses M3x6mm Flathead screws and if you don't mind the style of the screw then any Standard M3 screws should fit but don't mistaken it for HDD screws (#6-32 screws).
HTH
Regards
Marc_V
Dec 04, 2019NETGEAR Employee Retired
Welcome to the Community!
If you are talking about the Disk tray screws, you can use HDD screws with 3.5mm*6mm size. This should fit the trays as well.
Are you talking about the Chassis itself?
Regards
- SCUBAInstructorDec 04, 2019Guide
Yes, it is about the chassis. There are seven screws at the backside. I broke one of them (head ripped off) and need a replacement.
- Marc_VDec 04, 2019NETGEAR Employee Retired
Hi
Can you send us a screendshot of which part of the chassis.
It is about the screws inside the yellow circles in the attached image.
- Oct 02, 2015Retired_Member
