SCUBAInstructor
Dec 04, 2019Guide
RDD516/RN516 case screws
I need a replacement for some ReadyNAS case/housing screws. What type of screws do I need? Best Regards Jochen
- Dec 04, 2019
The Chassis uses M3x6mm Flathead screws and if you don't mind the style of the screw then any Standard M3 screws should fit but don't mistaken it for HDD screws (#6-32 screws).
HTH
Regards
SCUBAInstructor
Dec 04, 2019Guide
Yes, it is about the chassis. There are seven screws at the backside. I broke one of them (head ripped off) and need a replacement.
Marc_V
Dec 04, 2019NETGEAR Employee Retired
Hi
Can you send us a screendshot of which part of the chassis.
- SCUBAInstructorDec 04, 2019Guide
It is about the screws inside the yellow circles in the attached image.
- Marc_VDec 04, 2019NETGEAR Employee Retired
HTH
Regards
- Oct 02, 2015Retired_Member
