SCUBAInstructor's avatar
Dec 04, 2019
RDD516/RN516 case screws
I need a replacement for some ReadyNAS case/housing screws. What type of screws do I need?   Best Regards Jochen
  • Marc_V's avatar
    Marc_V
    Dec 04, 2019
    SCUBAInstructor
    The Chassis uses M3x6mm Flathead screws and if you don't mind the style of the screw then any Standard M3 screws should fit but don't mistaken it for HDD screws (#6-32 screws).
    HTH
    Regards
ProSupport for Business
