hezner1
Jan 09, 2021Tutor
1000 blinking blue light - reset
I have an older ReadyNAS 1000 unit which I have been using only as a backup destination for home folders on another ReadyNAS box. We had to power all equipment off yesterday for some electrical work...
- Jan 09, 2021
How to interpret the LED codes is here: ReadyNAS-LED.pdf . Power button alone fast blinking is Normal BIOS boot, this stage should not last for longer than 30 seconds. Otherwise, try re-seat SODIMM or replace SODIMM. If it still does not work, perform NAND recovery. If NAND recovery does not go through or does not solve problem, PSU is in question.
NAND recovery is another term for a USB recovery, which is likely what you need.
Sandshark
Jan 09, 2021Sensei
