wlcox
Sep 21, 2015Aspirant
Backup from RN102 to Dropbox - choose location?
Default backup location to Dropbox is in the Apps folder. Can I change that destination to another Dropbox folder? For example to a ReadyNAS folder in the root of my Dropbox instead of in the Apps ...
fordem
Sep 22, 2015Mentor
Looking at that, it would suggest that the app SHOULD have created a subfolder within the Apps folder of the dropbox, which as far as I can recall it does not do.
It may not be possible to create a readynas folder in the root of the dropbox, but it should be possible to create it within the apps folder, and based on what dropbox has said, it sounds like the creator of the app (which may be netgear) is the one who needs to do it.
wlcox
Sep 22, 2015Aspirant
Thanks - I'll check w/ Dropbox
BC
