JohnWB
May 13, 2013Aspirant
Best way to set up Backup with new USB2 drive
I have just increased the size of the drives in my Duo for 1tb to 2 tb as it was just about full. I did a backup of my Duo 1 before the increase (940g) which I have now copied to a new USB2 hard dr...
JohnWB
StephenB wrote: Since you did a factory reset to get 4K alignment, I think you will have to go through the overwrite process (I agree it is waste of time). It would be nice if Frontview backup let you start off incrementally, but it insists on doing a full backup the first time it runs.
Thanks once again for that, would it be best if i deleted all the files on the USB drive so I can see whats going on, or just hope it works ok.
