LodyJ
Aug 05, 2015Aspirant
Convert ReadyNAS Duo v2 to JBOD
Hi, I've got this old ReadyNAS Duo v2 with two 1TB harddisks which is running X-RAID. My system has changed and I don't need RAID anymore. Question : Is there any way, to convert the X-Raid optio...
- Aug 10, 2015
Sorry mdgm,...
I totally overlooked the fact, that the last suggestions came from you.... apologies for that...
As I have stated before... I'm really getting old.... grin...
Anyway I am equally grateful for your help on this.!!
Very best regards,
Lody J. Claessen
Aug 09, 2015Guru - Experienced User
LodyJ wrote:
It appeared, that, although the label said it was a v2 unit, I have a version1.
So... things changed completely...
Well, not really. The basic situation is unchanged. With either unit you need to back up your data and do a factory reset to switch to jbod.
Download the 4.3.8 RAIDar (PC version is here: http://www.downloads.netgear.com/files/ReadyNAS/RAIDar_Win_4_3_8.exe)
Then back up the data, and document the configuration of the NAS (including any add-ons).
Remove one disk from the duo, then initiate the factory reset procedure. You can do this from the web ui (click system, then update, then click on the factory default tab). Or you can do that using the procedure in the hardware manual (page 15-16): http://www.readynas.com/download/documentation/HM/Duov1_NV%2Bv1_HW_en_06Dec11.pdf
Using the web ui is easier.
Once you begin you have a short window to get the Duo to use flexraid.(~page 19 here: http://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf). You do this by launching RAIDar, and choosing setup. The select flexraid / raid-0.
The NAS will complete the factory install. Then hot-insert the second disk, and create the second jbod volume.
Then complete the NAS configuration, set up the shares, and restore the data from backup.
LodyJ
Aug 09, 2015Aspirant
Hi StephenB,
Thanks for your reply.
The procedure I mentioned in my previous message didn't quite work out.
- I did manage a manual factory reset
- I did get de "settings-dialog" in my RAIDar window.
- I did set it to Flexraid0
- But in the end, the unit still ran RAID1 on two disks.... so... no result.
Your procedure looks good, but.....
The link http://www.downloads.netgear.com/files/ReadyNAS/RAIDar_Win_4_3_8.exe) returns a "404-not found".
Have been looking around, but couldn't find it.... but..... I already installed RAIDar 6.0 for windows...
Do you think version 6.0 will do the same trick..???
Cheers,
Lody J. Claessen
