azerva
Jul 24, 2015Tutor
Data Volume Lost after Disk Replace #25483643
Hello ReadyNAS Community,
after a disk failure (disk 3), I replaced this disk. A volume resynchronization was started automatically. However, this resynchronisation failed with no obvious error...
mdgm-ntgr
Jul 25, 2015NETGEAR Employee Retired
Your logs show that disk 4 has been giving errors for quite some time.
It would have been good to have been asked before there was a big problem whether the errors were a cause of concern.
When you replace a failed disk, the resulting resync that puts heavy stress on all disks can finish off another disk that is failing.
ATA Error Count: 90 Reallocated Sectors: 696 Reallocation Events: 696 Spin Retry Count: 0 End-to-End Errors: 0 Command Timeouts: 0 Current Pending Sector Count: 48 Uncorrectable Sector Count: 48 Temperature: 47 Start/Stop Count: 1554 Power-On Hours: 14041 Power Cycle Count: 232 Load Cycle Count: 1555
Those ATA errors, reallocated sectors, current pending sectors and uncorrectable sector counts considered together indicate very clearly that this disk is bad.
An attempt to clone this disk e.g. using dd_rescue may be necessary.
This looks like a data recovery situation.
You may need to consider purchasing data recovery services. Support could explain the cost and the scope of what is covered.
azerva
Jul 25, 2015Tutor
Hi mdgm,
thanks for your reply. I remember only getting one e-mail notification from the system regarding disk 4, somehow I was not aware that there were so many errors reported by the disk already, otherwise I would have mentioned it. Also, disk 4 is online now, that's what I find a little strange. When disk 3 failed a week ago, it was really offline, i.e. red and could not start. I even tried putting in a usb docking port and it didnt boot up. Disk 4 however "seems" to be fine now. This is why I still have some hope left that there is something I can do.
Fri Jul 24 2015 2:15:52 Disk: Disk in channel '4' (Internal) changed state from ONLINE to FAILED. Fri Jul 24 2015 2:15:49 Disk: Disk in channel '3' (Internal) changed state from RESYNC to ONLINE. Fri Jul 24 2015 2:15:46 Volume: The rebuild operation has finished on volume 'data'. However, the volume is still degraded.
By loooking at the timestamps of the events, it would seem that the resync finished just seconds (02:15:46) before disk 4 failed (02:15:52), but I guess this is a reporting error and the events probably happened the other way around, and the "failure" of disk 4 caused the resync to fail and it was just reported the other way around. What do you think, is this a correct assumption? Otherwise, If the resync did finish before disk 4 failed, then I would expect to be able to use the device like I did after disk 3 failed, i.e. volume in a degraded state with disk 4 offline.
All in all it seems that disks 3 and 4 were of poor quality, since both were bought at the same time and seem to have failed at almost the same time, even before warranty ran out.
- mdgm-ntgrJul 25, 2015NETGEAR Employee Retired
The problem with the disk caused the resync to fail.
In the status log and elsewhere I see a number of mentions of errors dating back some months.
Before replacing a disk that has failed it is advisable to check to see if any other disks have problems as well as consider where you are regarding backups.
For new disk purchases I would go with e.g. WD RED disks or SeaGate NAS disks.
- azervaJul 25, 2015Tutor
mdgm wrote:The problem with the disk caused the resync to fail.
Hi,
thanks for your reply. I am also pretty sure that this is what happened. However, and I'd really like to come back to this, unlike disk 3 which failed completly, disk 4 is still accessible (hooked up to my PC right now) and I would like some advice or opinions about what I could at least try before giving up on the data. I have the Seagate Tools installed (since its a Seagate Disk), a SHORT DST Test failed. The tool recommends to use the DOS version to try and repair the bad sectors.
Should I give this a go or does anyone have any better ideas?
Thanks
Alex
- vandermerweJul 25, 2015Master
No.
Wait for Netgear support to see if data recovery is an option. If they haven't offered it, ask them.
If you start altering the data on the disks then it is likely you will make data recovery more difficult. It is possible that cloning disks and trying to reassemble the raid structure may be what is needed, but leave this to someone with expertise, and be prepared to pay for it.
- JennCJul 25, 2015NETGEAR Employee Retired
Hello azerva,
I replied to your PM. Like what mdgm and vandermerwe advised you to do, contact support and leave this to the experts.
The data you have in that disk 4 cannot be retrieved without the other 2 original disks. Put the disk back to the NAS bay where you removed it and have the system logs ready as you will have to give that to the support center.
You may need to prepare a spare disk to clone disk 4. But let support check first if it is still possible before getting one (if you do not a have spare disk and will have to buy).
here's what mdgm replied yesterday to this topic.
Those ATA errors, reallocated sectors, current pending sectors and uncorrectable sector counts considered together indicate very clearly that this disk is bad. An attempt to clone this disk e.g. using dd_rescue may be necessary. This looks like a data recovery situation. You may need to consider purchasing data recovery services. Support could explain the cost and the scope of what is covered.
