dayo
Jun 05, 2017Aspirant
HOW TO STREAM FROM MY READYNAS O MY LG TV
Dear Admin, i have a readynas model 3130 configured and working very well in my office. i newly bought 4 LG smart TV That supports DLNA, i assigned ip address to the 4 LG tv and was connected to ...
- Jun 05, 2017
Then the next step is to create plex libraries that include the folders that hold the media.
Plex has some getting-started guides here: https://support.plex.tv/hc/en-us/articles/200264746-Quick-Start-Step-by-Step-Guides
Jun 05, 2017Guru - Experienced User
There is a guide for ReadyDLNA here: https://kb.netgear.com/23069/What-is-the-ReadyDLNA-streaming-service-and-how-do-I-enable-it-on-my-ReadyNAS-OS-6-storage-system
You could also install plex - many smart TV's have a plex client. https://support.plex.tv/hc/en-us/articles/204080173-Which-Smart-TV-models-are-supported-
dayo
Dear Admin,
Thank you for you reply.
however, i have downloaded plex media to my pc. please, what next ?
How do will my ready nas connect to it?
- StephenBJun 05, 2017Guru - Experienced User
You need the plex server, not plex media.
Is your NAS running 4.2 firmware If so, the simplest option is to install Plex Server on the PC, then map the ReadyNAS media shares to that that PC (so they have a drive letter). Then you'd create the plex libraries, etc on the PC.
If you are running OS 6, then you could directly install the plex server on the ReadyNAS.
- dayoJun 05, 2017Aspirant
Thank you once again for your responds. please, i am running OS 6.7, at the admin page in Apps, i have searched for Plex server fo installations. nothing like such can be found in my readynas admin page i.e. Apps.
where can i find it in Plex Server in my ReadyNas.
please, i need to solve this ASAP..
Thank you.
Go to https://www.plex.tv/downloads/
Select "netgear", and a bit later on you'll choose the "Intel" download.
You then use the "upload" control on the apps page to install it.
