dayo
Jun 05, 2017Aspirant
HOW TO STREAM FROM MY READYNAS O MY LG TV
Dear Admin, i have a readynas model 3130 configured and working very well in my office. i newly bought 4 LG smart TV That supports DLNA, i assigned ip address to the 4 LG tv and was connected to ...
- Jun 05, 2017
Then the next step is to create plex libraries that include the folders that hold the media.
Plex has some getting-started guides here: https://support.plex.tv/hc/en-us/articles/200264746-Quick-Start-Step-by-Step-Guides
Jun 06, 2017Guru - Experienced User
dayo wrote:
But one more thing, advice me on what to do with the speed. it hangs when playing every now and then(i.e buffering). what can i do to my bufering problem?
Can you tell us a bit more about the network? Manufacturer/model of equipment on the network path from the router to the TV.
Also, is the TV is using ethernet? Or WiFi?
dayo
Jun 07, 2017Aspirant
Dear Stephen,
Thank you for your reply.
i have my Router connected to my gigabit switch port. my Gigabit switch port connected to the gigabit port of my readynas. The switch connected to my Ubiquiti AP. And finally my LG TV connected to my AP.
