stigpepper
Mar 10, 2018Tutor
Inactive volumes - data not available
Hi, My readynas could not be found on the network so I hard rebooted the box. After rebooting my volumes are unavailable and I'm receiving the error messages below: - Volume data RAID Leve...
- Mar 13, 2018
Have you tried booting to volume read-only mode? If your volume mounts in that the next step would be to make sure you have an up to date backup.
Are quotas enabled on your data volume (note quotas are used for showing space consumed by individual shares and snapshots, so even if you haven't set a quota on a share, quotas may still be enabled on your data volume)? If so, it's possible an OS Re-install may help as that would disable quotas on the data volume.
mdgm-ntgr
Mar 12, 2018NETGEAR Employee Retired
Can you send me a copy of your logs (see the Sending Logs link in my sig)?
stigpepper
Mar 13, 2018Tutor
Hi Mdgm,
I've sent the log files by email. Please let me know if you require further information. Thanks Stig
- mdgm-ntgrMar 13, 2018NETGEAR Employee Retired
- stigpepperMar 13, 2018Tutor
Hi Mdgm,
Great news, I'm able to access the data in the volumes in read only mode, which is a relief. I'll kick off the backups to ensure I've a copy of all my files.
I'm unsure if I'm using quotas but I'll attempt the OS install when I've backed up the data and will confirm if that has resolved the issue. Alternatively, I noticed that firmware 6.9.3 is available, would upgrading the firmware do the same thing?
FYI the backup will take a while to complete, so it might be a day or two before I respond.
Thanks for all your help, it is much appreciated.
Cheers, Stig
No a firmware update won’t do the same thing as an OS Re-install.
An OS Re-install resets some network settings, resets the admin password and disables quotas on the volume and extracts the OS over the top of itself.
A firmware update doesn’t reset settings or disable quotas on the volume.
If the OS Re-install resolves it, it would then be available to download a fresh set of logs, update the firmware and then download a fresh set of logs again.
