stigpepper
Mar 10, 2018Tutor
Inactive volumes - data not available
Hi, My readynas could not be found on the network so I hard rebooted the box. After rebooting my volumes are unavailable and I'm receiving the error messages below: - Volume data RAID Leve...
- Mar 13, 2018
Have you tried booting to volume read-only mode? If your volume mounts in that the next step would be to make sure you have an up to date backup.
Are quotas enabled on your data volume (note quotas are used for showing space consumed by individual shares and snapshots, so even if you haven't set a quota on a share, quotas may still be enabled on your data volume)? If so, it's possible an OS Re-install may help as that would disable quotas on the data volume.
mdgm-ntgr
Mar 13, 2018NETGEAR Employee Retired
No a firmware update won’t do the same thing as an OS Re-install.
An OS Re-install resets some network settings, resets the admin password and disables quotas on the volume and extracts the OS over the top of itself.
A firmware update doesn’t reset settings or disable quotas on the volume.
If the OS Re-install resolves it, it would then be available to download a fresh set of logs, update the firmware and then download a fresh set of logs again.
stigpepper
Mar 21, 2018Tutor
Hi mdgm,
I've successfully backed up my data, performed an OS reinstall and my volumes are now accessible.
New log files have been downloaded and submitted via email, I'd appreciate if you would review the logs and confirm if all is in order.
Cheers, Stig
- mdgm-ntgrMar 21, 2018NETGEAR Employee Retired
Looks good. You may wish to update to 6.9.3.
- stigpepperMar 21, 2018Tutor
Hi mdgm,
I've upgraded the firmware to v6.9.3 and everything seems to be working as expected. Thanks a mill for your help and support as I'd feared I would've lost approx. 3 months data or would needed to pay for netgear again for extended support and data recovery.
To give me more resiliance going forward I've bought an old HP Proliant server which I'm going to use for backup purposes but hope to be able to use one of the 6TB HDD's from the ReadyNAS.
I'd appreciate if you would confirm if I can swap the 6TB disc with a 2TB disc or does it need to be a like for like replacement.
Thanks Stig
- StephenBMar 22, 2018Guru - Experienced User
No. You can't shrink a RAID volume from the web ui. You'd need to destroy the volume, replace the disk, and create a new one. Then recreate your shares and reload the data from backup.
