These are the last entries in the log...
| System: Antivirus scanner definition file was updated to 57.23054. |
| System: ReadyNASOS background service started. |
| System: ReadyNASOS service or process was restarted. |
| System: Antivirus scanner definition file was updated to 57.23048. |
| Volume: Less than 20% of volume data's capacity is free. Performance on volume data will degrade if additional capacity is consumed. NETGEAR recommends that you add capacity to avoid performance degradation. |
| System: Antivirus scanner definition file was updated to 57.23042. |
| Volume: Less than 30% of volume data's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection snapshots will be deleted when volume free space is less than 5%. |
| System: Antivirus scanner definition file was updated to 57.23036. |
| System: Antivirus scanner definition file was updated to 57.23030. |
| System: Antivirus scanner definition file was updated to 57.23024. |
| System: Antivirus scanner definition file was updated to 57.23018. |
| System: Antivirus scanner definition file was updated to 57.23012. |
| System: Antivirus scanner definition file was updated to 57.23006. |
| System: Antivirus scanner definition file was updated to 57.23000. |
| System: Antivirus scanner definition file was updated to 57.22994. |
| System: Antivirus scanner definition file was updated to 57.22988. |
System: Antivirus scanner definition file was updated to 57.22982.
