ramram
Feb 13, 2017Aspirant
Inactive volumes!
Dear all Please help my drive has turned like this...this drive is full of DATA!!!! :((
mdgm-ntgr
Feb 13, 2017NETGEAR Employee Retired
So you don't have a backup?
Sounds like you should contact support though there would be some costs involved with looking into this.
ramram
Why should I do a backup when its a mirrored RAID :(
What's the contact info of SUPPORT please?
- aalexandrebetaFeb 13, 2017Master
You canturn off the anti-virus too!
- ramramFeb 13, 2017Aspirant
its not letting me!
- mdgm-ntgrFeb 14, 2017NETGEAR Employee Retired
You could go to netgear.com/support and fill out the contact us form. You'd be presented with your options to turn it into a case. There would be some costs involved. If it ends up being a data recovery case it could cost quite a bit.
