cdkotran
Mar 02, 2018Aspirant
Re: ISCSI disconnection issue in firmware 6.9.2
I upgraded to 6.9.2 yesterday and OMG I have been going down most of the day with iSCSI issues. If only I would have known about this problem I would have stayed on the older firmware (pre 6.6.x).
mdgm-ntgr
Mar 02, 2018NETGEAR Employee Retired
What are you using iSCSI for?
Any other services running?
Are you using any apps?
- cdkotranMar 04, 2018Aspirant
No apps.
Was using iSCSI for VMware.
Further diagnostics....
Switched over to NFS and same issue. Load comes on.... protocals drop. eth0 eth1 or both.
Switched over to alternate backup ReadyNAS and problem does not reproduce.
Factory reset this troublesome ReadyNAS and it hangs on boot at 90 to 94%. Still under warranty so I need to figure out next step.
- mdgm-ntgrMar 04, 2018NETGEAR Employee Retired
So the firmware update was a coincidence.
You could have a failing disk.
Did you happen to download the logs before trying the factory reset? If so, have you checked smart_history.log?
- cdkotranMar 08, 2018Aspirant
Well after monitoring for a few days I've finaly been able to catch the 2nd unit doing the same thing. Bonded or not bonded my NFS share goes away briefly thus causing my VMs to temporarily pause.
No, no harddrive failures on either unit.
When I get a chance I'll gather the logs and send them on. At this point...... I have no stable ReadyNAS units; just a bunch of angry customers.
