Alex_CCIM
May 01, 2020Apprentice
Multi-Gig support for RN214 and RAX120
I have a RAX120 and RN214. Can I enable Multi-Gig support for my RN214 from my RAX120?
- May 05, 2020
I received the following response from Level 2 Technical Support:
Regarding the solution you propose, it would be irresponsible for Netgear to tell you that if it works and this has not been previously tested.
I've done some research, but the unit doesn't support USB network adapters.
But, If you create a bounded (LAG between the NAS and your router) will improve performance, and that is something that can be achieved,
in case you want to get higher transfer speeds, you will have to look for other ReadyNAS, because this NAS only supports speeds up to 1 gbit.
Alex_CCIM
May 05, 2020Apprentice
WhoCares_
May 05, 2020Mentor
OMG. Typical L2 answer. Yes, outof the box the ReadyNAS doesn't support (multi-gig) USB adapters. But that doesn't mean it can't be made to. The only thing that prevents building drivers for the ARM based boxes is the missing patches NTGR makes to the Linux kernel, as I found out today. They were included in the GPL archive up to 6.9.3 but are missing since (only from the -arm and -alpine kernels to be precise). Why that is the case I can only speculate. Buest guess is a mess-up in the pipeline that builds the GPL archive. If time permits I'll try to adapt the older patches to the newer kernels and see if I can build working drivers with that. That doesn't mean there are drivers for the multi-gig USB adapters available, but at least a lot of other USB add-on devices could be made to work with the ARM boxes.
-Stefan
