jdou
Jan 05, 2019Aspirant
NAS 104 OS reinstall
Hi,
I think I messed it up. I was trying to do a factory reset but from the looks of it while pressing the backup button I went a step further and it is doing an OS reinstall but has been at it for...
JohnCM_S
Jan 09, 2019NETGEAR Employee Retired
Hi jdou,
The OS reinstall procedure should not take that long to complete. Normally, it should only take a few minutes for it to complete the process. You can try forcefully shutting down the NAS.
jdou
Jan 09, 2019Aspirant
Yes I had to shut it down by unplugging it! I tried using Factory default installation and had the same problem. Someone told me it's a flash problem. How do I go about it?
