Pyronought
Mar 26, 2019Aspirant
NETGEAR RN10200 - No idea
New to NAS,
Have a ReadyNAS 102, which i had set up 3 years ago, and just left running in my cabinet.
I would like to reuse it, however i cannot talk to it outside of RAIDar, and even then it...
Mar 26, 2019Guru - Experienced User
It's easier if you connect the NAS directly to your router. So I suggest starting there instead of connecting it directly to your laptop.
Pyronought
Apr 08, 2019Aspirant
Clarification router or computer? Statement says router instead of router.
Is there a way to hard reset the unit to start again with it?
- SandsharkApr 08, 2019Sensei
Connect to router so it and your computer are automatically assigned IP addresses in the same subnet (assuming you didn't previously have it connected to a router with a different subnet and set it for a fixed IP).
An OS re-install (not a Factory Default) will reset the password and DHCP settings but not harm the data. But it's a bit tricky on a unit without a display panel.
- StephenBApr 08, 2019Guru - Experienced User
Pyronought wrote:
Clarification router or computer? Statement says router instead of router.Sorry, I fixed the typo.
Pyronought wrote:
Is there a way to hard reset the unit to start again with it?Yes. There is a factory default boot option that reformats the disks (and of course destroys your data). There'a also the OS reinstall that Sandshark mentioned - which is non-destructive. I agree it's a bit tricky with no LCD display. You can also zero the disks (connecting them to a PC and using Seatools or WDC's Lifeguard software). Then reinsert them into the NAS and power up - that will force a fresh factory install.
The boot menu options for your NAS are described on pages 20-21 of the hardware manual ( http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf )
A full zeroing isn't usually needed, just use Disk Management to delete all the partitions.
Correct. Also, Lifeguard has a "quick" zero test that will delete all the partitions quickly.
But since the system has been sitting around for some years, it might be a good idea to run the disk diagnostics anyway.
