Sinegraf
Jul 07, 2019Guide
no network after lightning strike
No network link no network activity lights USB backup works So disks and RAID systems work (Raid5 4x3TB now 4,2/8,1T free) So a simple solution could be to move the disks to a new 4Bay Read...
- Jul 21, 2019
Sinegraf wrote:
NV + v2 RAID had the latest available software for that model ..
Now I don't know if it meant X-RAID gibbrich ..
If it has X-RAID, it is probably the "writing order" that is special
the writing order can be affected by "parity delay"
Someone who knows if it is 100% normal (RAID5 standard) or a separate secret rule?Your NAS uses software RAID (mdadm). XRAID is layered on top of mdadm - it manages RAID groups for you automatically (which allows for expansion of the array). But underneath it is just mdadm - there is nothing proprietary about the on-disk structures.
FWIW, it sounds like R-studio isn't finding the mdadm superblock. It's possible that the superblock was corrupted when the lightning stuck. Though I'd have expected an error on the LCD panel if that were the case.
As I said earlier, I don't know what parameters are used when the array is created.
Sinegraf wrote:
can ReclaiMe manage NETGEAR NAS?
Folks have used it for OS-6 ReadyNAS (which uses the BTRFS file system). I don't recall seeing it used for OS-5, but it likely would work.
The free tool I pointed you too will only find the RAID parameters. The paid version is needed to recover files. However, you can alternatively download the paid version, and see if it can recovery anything before you actually purchase it.
You could also contact R-Studio support, they might know the parameters used by your NV+ v2.
Jul 20, 2019Guru - Experienced User
Though your parameters look reasonable, I don't know the underlying RAID parameters (and don't own a v2 NAS). I am thinking that you might want to try a different free tool that might correctly detect them: http://www.freeraidrecovery.com/?s=rd Netgear ( JohnCM_S ) might also chime in and tell you what they are.
It'd probably be smart to clone all the drives if you can (since they are the only copy of the data).
Sinegraf
Jul 21, 2019Guide
- StephenBJul 21, 2019Guru - Experienced User
- SinegrafJul 21, 2019Guide
I need to study mdadm... :)
it found some mdadm blocks, on the "volyme" but they seem "locked" ..
Thx, Then I have a guide on how it might be possible to open.. - SinegrafJul 23, 2019Guide
Short description, for RStudio
forget to try to create traditional "virtual" RAID5 and similar..
concentrate on opening the mdadm volyme, and let RStudio scan the entire volume, The information on how it is created will be found when scanning.. for me, the scan of 8TB took 25 hours
when you choose recover, turn off exporting "hidden / extended attribute's"
expect 15-20 hours per TB
Great tips for those with NAS as the guarantee gone out ;) - StephenBJul 23, 2019Guru - Experienced User
Sinegraf wrote:concentrate on opening the mdadm volyme, and let RStudio scan the entire volume, The information on how it is created will be found when scanning.. for me, the scan of 8TB took 25 hours
expect 15-20 hours per TBThanks for sharing this info.
