mfb9
Oct 20, 2022Aspirant
OS6 NAS and Riello iDialog 400 UPS
Hello. I have a couple of NAS's, running OS6, and have had a disk failure from a power cut, so I have bought a UPS. i thought that as the current drain is small compared to a server etc, and all i ...
Oct 21, 2022Guru - Experienced User
mfb9 wrote:
If I put the good one, or both, into a spare RND104, will it read them, or will it start rebuilding the RAID and deleting everything? Or a 314 - I can drag either into service temporarily.
You should be able to migrate the disks to either system. In the case of the RN314 it will convert the OS to x86, the RN104 is also ARM. So I'd go with the RN104 in this situation.
It might be wise to migrate just one disk, as that eliminates the possibility of a resync. It shouldn't do a fresh install unless you explicitly do a factory default.
mfb9
Oct 21, 2022Aspirant
Thanks very much. But see also my replies to further answers, for al of which i am very grateful
mark
