dschwartzer
Dec 27, 2016Luminary
Ready DR Job Failure
I have a ReadyNAS 526X that has Several ReadyDR jobs that are sent to a ReadyNAS 314. Both units are running OS 6.6 The ReadyDR has been working perfectly for weeks and starting 2 days ago I starte...
- Dec 28, 2016
FramerV:
Thanks for your quick response. After doing some additional trouble shooting, I didcovered that as the result of an apparent router firmware update, the IP address on the RN314 (which received the ReadyDR jobs), did in fact, change two days ago. Since the ReadyDR destination is IP specific, that caused the jobs to fail.
Unfortunately, there does not appear to be a way to modify the destnation address so I had to delete the existing jobs and recreate all of them, using the new IP address. That appears to have corrected the issue as the jobs all ran correctly.
David
FramerV
Dec 27, 2016NETGEAR Employee Retired
Hi dschwartzer,
Do you have other ReadyDR jobs that are working?
Can you try to create a test ReadyDR job? I am going to check further on the error that you are getting.
dschwartzer
Dec 28, 2016Luminary
FramerV:
David
