dschwartzer
Jul 22, 2017Luminary
ReadyDR job failure: Input/output error
I use a RN526X as my primary NAS and use a RN314 for backup and for the ReadyDR jobs. I have has ongoing issues where the 314 becomes Read Only after about two weeks of backups. I did a factory res...
crazy_toy
Jul 26, 2017NETGEAR Expert
Thanks for your information
1.shares become read-only , all shares on 314 become read-only or readyDR share become read-only? if readyDR share was read-only , it's correct
2.Did 314 has enough capacity? if 314 has not enough capacity , readyDR job will raise input/output error
dschwartzer
Jul 28, 2017Luminary
Thanks for your response. The 314 has plenty of available capacity with well over 1TB free.
I know that the ReadyDR shares are Read-Only for everything but the ReadyDR jobs but it appears something happens to them along the way if the 314 is rebooted.
I continued to get the input/output error message through yesterday's backup attempt. In an effort to resolve that I rebooted both the 526 and the 314 last evening and sure enough. This morning, instead of the input/output error message, I am back to getting the read-only error message.
For each ReadyDR job I receive the following message:
ReadyNAS Alert Message (ReadyNAS625 ReadrDR: Warning)
ReadyDR job failure: Read-only file system [Ready DR Share Name]
This has always happened after the ReadyNAS units are powered down and and restart the next day. Now that this has occurrfed, the 314 is basically locked and the entire volume is read only.
I tried to create a new share and get this error:
Error:
1013050001
Could not create requested share.
The 526 volume is still OK and I can create new shares and write data to the shares with no problem but the 314 is locked.
This has happened every time I set up the ReadyDR volumes.
Any thoughts or suggestions would be appreciated.
David
- BotanyBaySep 27, 2017TutorI am seeing the same issue with a brand new 626 which is currently the target for readydr jobs running from a pro6.
Both units are running 7.6.5, waiting for 7.8.1 due to known issues with apps in 7.8.0
Problem showed up after rebooting the new 626.
If I go through each share and look at the settings some of them will start working for awhile before failing again. Some are not corrected this way.- Marty_MOct 03, 2017NETGEAR Employee Retired
I believe you are referring to firmware on 6.6.5 and 6.8.1 on your last response. It does appear that there was an issue created for this concern and the fix was provided on firmware version 6.8.0 that time. However in your case you are encountering the same problem. Please try the following steps and check if that will make any difference.1. Disable quota.
2. Don't keep too much snapshots.
3. Set a speed limit.
4. Try not to let two ReadyDR jobs running at the same time.
Marty_M
NETGEAR Community Team- BotanyBayOct 05, 2017Tutor
Marty_M
NETGEAR Community TeamThank you for the suggestions.
In this case I don't have quota's running (unless there is something set by defaut
I am not sure what "too many snapshots" would be, I am using the smart snapshots which have been running since about october of last year when I migrated from OS4 -> OS6, so there are probably 10 monthly snapshots and the others as expected.
I will try putting a limit on speed.
I have a series of about 15 ReadyDR jobs which are in the queue and I assume run sequentially, I created them using the web interface, is there something I need to do inorder for them to not run at the same time.
Also, the ones which fail due to being read only filesystems will not start even if run independently, how do I correct for this?
Thank you again for all of the help!
