Fandango2022
Nov 03, 2022Apprentice
ReadyNAS 2100 FrontView blank page - Firmware 4.2.31
Hi, Not sure If I am in the right place but here goes as I need some help. I have three readyNAS 2100's. I have had no issue installing OS6 on the first two. This third one did not like it an...
Fandango2022
Dec 28, 2022Apprentice
Hi JeraldM ,
Yes I can boot into Tech Support mode and here is the debug code -
Also, here is screenshots of the serial no. etc.
Thanks for replying.
Regards
@Fandango2022
JeraldM
Dec 28, 2022NETGEAR Employee Retired
Hi Fandango2022,
Thanks for the response!
However, your NAS cannot be located on our end.
Just to confirm, do you still have the NAS in Tech Support Mode?
Is the NAS also connected in a dual-NAT network as well?
JeraldM
NETGEAR Community Team
- Fandango2022Dec 28, 2022Apprentice
Apologies JeraldM , I did not realize you needed it to remain in Tech Support mode at this stage. It is now running in Tech Support mode (code 53426) with a single Ethernet cable connection to a hub on my network. Do you require two Ethernet cables connected?
Regards
- JeraldMDec 28, 2022NETGEAR Employee Retired
Hi Fandango2022,
There's no need to connect 2 Ethernet cables to it.
In the meantime, please keep it to Tech Support Mode by not performing a reboot on the NAS.
Please bear with us as we check on this.
JeraldM
- Fandango2022Dec 29, 2022Apprentice
Hi JeraldM ,
Are you able to see the NAS now? It has been running all night. Can I turn it off now?
Regards
