Piemaster
Oct 28, 2015Aspirant
ReadyNAS 314 running slowly after 6.4.0 upgrade
Since upgrading my 314 to 6.4.0 it's been running very slowly taking about 30 seconds to login to the admin page. Sometimes it doesn't even load it. Also AFP/TimeMachine connections are now very in...
BennyKind
Oct 30, 2015Guide
Netrage2 I dont know if this will help you but we were having very similar problems.
I managed to get on the web interface for about 10 minutes without it dropping out. In those 10 minutes i managed to delete some of the snapshots and set the snapshot schedule to never.
This did not solve the problem completly but it did give me longer on the web interface to give me time to delete the remaining snapshots.
At first the 316 was still unusable but the next morning it was accessible, it wasnt sluggish and I have been using it as normal again for the last 5 days.
So basically try and delete any snapshots you have on there and remove any snapshot schedule. Although it means that you wont have any snapshots, it does mean that you can at least use your NAS until Netgear release some sort of fix for this.
I hope that helps you.
Netrage2
Oct 30, 2015Aspirant
Thats interesting as my first login time was around 10 minutes as well. I used the time to pull some important files off the drive and delete around 1TB of data that I dont need but then it dropped out.
How are you removing the snaphots, I have never removed them before and given I only have a few minutes to do it I would welcome your technique.
