airwaves2020
Aug 30, 2026Aspirant
Readynas duo v2 and seagate ironwolf
Hi, replaced a failed drive in my readynas with this https://www.scan.co.uk/products/4tb-seagate-ironwolf-st4000vn006-nas-hard-drive-35-hdd-sata-iii-6gb-s-5400rpm-256mb-cache-cmr And the readyn...
airwaves2020
Aug 31, 2026Aspirant
Thanks for you help, I have done some more testing and the drive works outside the enclosure, so it's the enclosure. Looking for a replacement now, all my files are backed up in the cloud, not going to lose anything
Sep 01, 2026Guru - Experienced User
airwaves2020 wrote:I have done some more testing and the drive works outside the enclosure, so it's the enclosure.
Do you have the "real" v2? (ReadyNAS Duo v2 label on the front panel)?
Or do you have the original Duo (ReadyNAS Duo label on the front panel)?
