nsne
May 25, 2017Virtuoso
ReadyNAS error: "mount_block_root+1f1"
After installing the 6.7.3 firmware (6.7.1 > 6.7.3 upgrade), I'm seeing the error message "mount_block_root+1f1" on the LCD. I was going to try the USB Recovery method, but I saw in this similar thre...
- May 30, 2017
USB Recovery with a variety of thumb drives, syslinux.exe versions and 6.7.3/4 didn't work on the unit that was having trouble.
Netgear sent a replacement 314, and the USB Recovery process worked great (on the first try!) for updating the firmware.
So the problem was that 6.7.3 effectively bricked my unit.
mdgm-ntgr
May 26, 2017NETGEAR Employee Retired
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
If you can't do USB Boot Recovery despite trying multiple different USB keys and following the directions you'll need to contact support.
nsne
May 30, 2017Virtuoso
- cengiqueJun 22, 2017Aspirant
I just upgraded to OS version 6.7.4 and it also practically bricked my unit. Now I'm getting this error at bootup. Although the first reboot after the upgrade went fine. I will try the USB recovery method.
What's the accepted method for the USB recovery? Do we need to downgrade to before 6.7.3?
In particular, do we install the latest 6.7.5 image? I have downloaded the experimental USB recovery tool and placed the 6.7.5 image under x86/, but my when I boot my RN314, it does not go further than saying "Boot from external USB".
- cengiqueJun 27, 2017Aspirant
cengique wrote:
cengique wrote:I just upgraded to OS version 6.7.4 and it also practically bricked my unit. Now I'm getting this error at bootup. Although the first reboot after the upgrade went fine. I will try the USB recovery method.
I was able to rescue my unit using the USB recovery tool with a different USB stick, too. I think forgetting the "Run as administrator" was the problem the first time. Or it could be that the first stick I tried was unbootable for some reason (some are like that).
- mwsJun 26, 2017Aspirant
So is that the solution when it fails and you went through all the steps, booting to a valid, prepped, FAT32, 32gb thumb drive? Get them to send a new unit?
I ran through the posted solution (using fw 6.7.5), and it was booting to the USB drive, but never said anything about firmware. Then got same error message (mount_block_root+1f1)
I'm going to play with mine some more-- maybe try to boot to an older firmware. The original failure was after I told it to upgrade to 6.7.4...
This unit is an RN716x with 6x6tb drives (=single 27tb volume), using firmware 6.7.1 (last time it worked). Been in service for almost a year with no problems until now.
I have 3 others just like it that all went to 6.7.4 okay, plus some RR3312 (12x10tb=90tb volume) units that also upgraded to 6.7.4 just fine.
- nsneJun 26, 2017Virtuoso
mws wrote:So is that the solution when it fails and you went through all the steps, booting to a valid, prepped, FAT32, 32gb thumb drive? Get them to send a new unit?
Yes, the new unit was the solution. And I think that's confirmed by the fact that the new unit carried out the USB Recovery process successfully using the same USB stick that didn't work on the old unit. Believe me, I tried every USB stick I could find and every variation of the USB Recovery software.
I have a legacy Ultra 4 that upgraded through all the 6.7.x firmware releases without incident. Still waiting to see how 6.7.5 works for others before upgrading, though — once bitten, twice shy.
Well, we just fixed ours by going through the process again with a smaller (16gb) thumb drive! Now has 6.7.5 and seems to be working fine.
Thanks for the help!
I have 3 others just like it that all went to 6.7.4 okay, plus some RR3312 units that also upgraded to 6.7.4 just fine.
Oops! Double post? I hit post once, and it said fix errors and resubmit, so I did. Didn't meant to post it twice.
