colmosiris
Aug 03, 2015Aspirant
ReadyNAS model RND4000-100EUS - replacement power supply
Hi there! I have a ReadyNAS box that needs a new power supply. The box and cable that connects the NAS to the wall socket that is, not the internal power unit. I've found some on ebay, but they m...
- Aug 03, 2015
All you need is the correct cable, there is no transformer. The input voltage to the supply can be 100-240.
For instance this: http://www.amazon.co.uk/Mains-Cable-Power-Monitor-Kettle/dp/B003P49P1I
Davexyz2
try a search on amazon using synology power supply yes not what you really expect. They the replacement supply works on readynas with a 4 pin plug. It will have the specs as well
Harleyfart
Oct 09, 2015Tutor
I found a power supply, OEM replacement, on Amazon, albeit was in Great Britain, that was designed for the ReadyNAS NV+ v1, in May of this year. $110.00
http://www.amazon.com/gp/product/B000W3X480?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
- colmosirisOct 23, 2015Aspirant
Thanks very much, but it wasn't the internal power supply I was after, but a cable/transformer to connect the box to the mains. Turns out all I needed was a kettle lead. (I imagine this is a UK thing, as it has an earth lead. No idea what the US equivalent would be.)
So now I've got it poered up, I need to work out why I can't access all the shares, but that's another post for another time! :)
- HarleyfartOct 23, 2015Tutor
I had problem accessing shares after losing my power supply. Had to reformat ALL HDDs to regain access....unfortunately, that means lost data. Well, it did for me. Thankfully, the NAS was not the only place that I had that data. Now, I have 3 NAS devices [18TB w/RAID5], 4 external HDDs [8TB cap]...one can never have too much redundancy.
- StephenBOct 23, 2015Guru - Experienced User
I had no issues booting up when I replaced a failed power supply.
However, a lot of posters report that they have lost data after an unexpected power cut. That's one reason I always recommend a UPS for the NAS.
Of course a UPS can't protect you when the PSU fails. Which is why (like you) I also stress the need for backups.
