robohofo1
Nov 15, 2022Aspirant
ReadyNAS NV+ - stuck on boot (DRAM fail?)
Hi... I have a oldie but goldie ReadyNAS NV+ (e.g. RND4000). It has 3 disks in it and a 1GB memory expansion. It's stuck on boot, blowing the fans at full speed and not getting far. Looking at t...
- Nov 16, 2022
There is no onboard memory. When you installed the 1GB, you removed the 256KB SODIMM.
It could still be an address line, buffer, or something else, but the SODIMM is most likely, the only replaceable part, and very cheap these days. If you still have the original one, you could re-install it and see if all is well, or just buy and try a replacement.
Sandshark
Nov 16, 2022Sensei
- robohofo1Nov 16, 2022Aspirant
Thanks for the response. I found a older memory module somewhere in a crevice of a drawer - installed it and it boots up!
Thanks!
