tgtbatq
Jul 22, 2017Aspirant
ReadyNAS NVX Not Expanding Storage
I inherited this from the company I work at, and it's been working flawlessly as storage for my home Plex server (couldn't ever get plex plugin to work on the NAS (I guess one issue at a time), so it...
tgtbatq
Jul 23, 2017Aspirant
So are you saying that I'll need two 3tb drives for it to show any increase in space, and adding one doesn't do anything? I have 4/4 drive bays filled up, but only one is 3tb -- the other 3 are 1tb each.
jak0lantash
Jul 23, 2017Mentor
- tgtbatqJul 23, 2017Aspirant
So can I just re-seat one of the current drives and then it will rebuild?
- StephenBJul 24, 2017Guru - Experienced User
If you want it to grow, you need to replace another 1 TB disk with a 3 TB model.
- SandsharkJul 24, 2017Sensei
The unit is set for XRAID redundancy, which is built in layers. You currently have a 4x1TB array (which yields 2.71TiB plus redundancy) and an extra 2TB on the 3TB drive with nothing to pair itself with for redundancy. If you swap another 1TB for a 3TB, then you will retain the 4x1TB layer and add a 2x2TB layer. Each of the other 1TB's can be swapped later for a 3TB and add another 2TB.
