SteveMathews's avatar
Nov 20, 2016
ReadyNAS Pro 6 stuck at Booting...
Help!   For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete.   Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the A...
  • StephenB's avatar
    Nov 22, 2016
    SteveMathews wrote:
    if these are any help
    Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
    If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
    Then perhaps just try booting again.
ProSupport for Business
