SteveMathews
Nov 20, 2016Guide
ReadyNAS Pro 6 stuck at Booting...
Help! For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete. Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the A...
- Nov 22, 2016
SteveMathews wrote:
if these are any help
Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
Then perhaps just try booting again.
mdgm-ntgr
Nov 21, 2016NETGEAR Employee Retired
Let us know how you get on. It's quite possible the problem could be a full 4GB root volume, but it could also be something else again.
SteveMathews
Nov 22, 2016Guide
scrub that last comment - i was being a muppet!
Now i'm using telnet i'm in and have successfully mounted the drive
/dev/md0 is size 4.90G, used 2.9G Available 721.1M 81% used
is this full enough to prevent booting - i seem to recall in recent times it has been at about the 70-80% level....
thanks
steve
