SteveMathews
Nov 20, 2016Guide
ReadyNAS Pro 6 stuck at Booting...
Help! For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete. Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the A...
- Nov 22, 2016
SteveMathews wrote:
if these are any help
Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
Then perhaps just try booting again.
Nov 22, 2016Guru - Experienced User
SteveMathews
Nov 22, 2016Guide
Bingo!
It's working now!
The worst files seemed to be in my squeezebox lib folder
artwork - 200Mb, and
spotify cache - 150Mb
I deleted both of these and it seems to be booting-up fine now.
I've ssh'd back in and the 4G partition is now at 71% which is higher than i'd like so i'll do a bit more digging over the next few days
But i'm just relieved to have got it back up
Thanks v much StephenB
Steve
- StephenBNov 22, 2016Guru - Experienced User
SteveMathews wrote:
It's working now!
Great! Glad I was able to help.
