flattened
Aug 10, 2017Apprentice
ReadyNAS4312 HyperV VHD over iSCSI or SMB? RR4312
Hello. We have a new ReadyNAS RR4312. It has 10*2TB SATAs. It will be used to hold the VHDX files from a Windows Server 2016 HOST. The HOST & NAS are connected via 2*10GB SFP+ The HOST ser...
Aug 10, 2017Guru - Experienced User
flattened wrote:
Maybe the NAS storage should be split from the autoconfigured X-RAID (raid 6) to maybe a RAID1 for the VHDX volume to give it more speed, and the remaining 8 disks be reset up as X-RAID (If this is possible?)
You can't mix flexraid and xraid.
But you can switch to flexraid and create a second volume with the remaining 8 disks. There are some other raid modes available that you could explore (RAID10 and RAID50), which should give better performance than RAID-6. They would have higher overhead though.
flattened
Hi Stephen,
Thanks for your reply it is always good to hear from you.
I'd taken then plunge already regrading the NAS RAIDs
1* RAID 1 (2 disks) - I'll iSCSI this one and use an iSCSI initiator on the Hyper-V host.
1* RAID 5 (7 disks)
1*Global Hot spare.
It also seems I need to use iSCSI between the Windows HOST and the NAS for VHD storing in this scenario too as SMB is not available to Hyper-V directly to the NAS share. The only SMB shares allowed are those that are shared out from another separate Windows Server with shared storage configured.
