whc
Nov 02, 2019Aspirant
Rebuilding shares using SSH possible?
Just mistakenly deleted shares when I deleted stuck snapshots using SSH, is it possible to rebould those shares with SSH, have taken screenshot, so have the ID and gen numbers, maybe a SSH command ca...
whc
btrfs restore, don't understand how to put togheter a command line for restore a share, cannot fint any examples online, below is the options:
btrfs restore [options] <device> <path> | -l <device>
Try to restore files from a damaged filesystem (unmounted)
-s|--snapshots get snapshots
-x|--xattr restore extended attributes
-m|--metadata restore owner, mode and times
-S|--symlink restore symbolic links
-v|--verbose verbose
-i|--ignore-errors ignore errors
-o|--overwrite overwrite
-t <bytenr> tree location
-f <bytenr> filesystem location
-u|--super <mirror> super mirror
-r|--root <rootid> root objectid
-d find dir
-l|--list-roots list tree roots
-D|--dry-run dry run (only list files that would be recovered)
-F force (do not prompt on large files looping frequently)
-X eXtreme search (use both BTRFS_DIR_ITEM_KEY and BTRFS_DIR_INDEX_KEY)
--path-regex <regex>
restore only filenames matching regex,
you have to use following syntax (possibly quoted):
^/(|home(|/username(|/Desktop(|/.*))))$
-c ignore case (--path-regex only)
whc
Or maybe there is a command for using rsync, and backing up all data on the nas drives, no matter if deleted or not?
