swehjo's avatar
swehjo
Guide
Jan 06, 2018
Replacing NV+ with what?!
Maybe this is not the correct forum for this type of question?!   Have been running an old NV+ in RAID configuration with 4 x 1TB disks until today. The power supply failed with a "bang". Time to r...
  • StephenB's avatar
    Jan 06, 2018
    swehjo wrote:
    Should I go for a 214 or a 314? Or something else?
    All of these models are much faster than your NV+, so they will all be sufficient.  However, the RN314 was replaced by the RN424 last year.   Anything you'd buy now would be older inventory.
    The RN214 is classified by Netgear as a home NAS so it has a three year warranty..  The RN300 and above are classified as business NAS, and have a 5 year warranty.
    Looking at Amazon prices, I'd probably go with the RN424 - about $100 more than the RN214, but has that extra two years of warranty.
    You can certainly use your existing disks, though the new NAS will need to reformat them.  If they aren't on the current HCL, then Netgear might deny support if you were to have an issue.  Hardware warranty wouldn't be affected.
ProSupport for Business
