MMcD3v1
Jul 01, 2017Tutor
RN 214 OS 6.7.5. DNLA duplicated songs listed on receiver
On my 214 running OS6.7.5 I'm seeing duplicated (actually 3) listings of every song in my music library on my Yamaha receiver running the most recent version of its firmware. The song/files are not du...
MMcD3v1
Jul 04, 2017Tutor
Shares have snapshots enables. I had allow snapshot access - it was checked.
I have now unchecked and disabled DLNA then re-enabled and did manual a manual rescan
I still see three titles of each song.
Now I was thinking. My music, pictures and videos are each in separate folders in the same share: "media". This is how I had it on my NV+ And it worked. But there are 3 folders. Could be a coincidence. Absent other fixes you might suggest I was thinking of moving the files to separate shares.. recommendations?
Also -thank you for the time and previous suggestions.
- StephenBJul 04, 2017Guru - Experienced User
MMcD3v1 wrote:
Shares have snapshots enables. I had allow snapshot access - it was checked.One theory busted I guess :smileyfrustrated:
MMcD3v1 wrote:
Now I was thinking. My music, pictures and videos are each in separate folders in the same share: "media". This is how I had it on my NV+ And it worked. But there are 3 folders. Could be a coincidence.I think it is a coincidence.
MMcD3v1 wrote:
I was thinking of moving the files to separate shares.. recommendations?You could try installing plex, and see if it has a similar problem. It includes it's own DLNA server, so you don't have to access the media with the plex app.
Though your idea is also a good one - basically forcing ReadyDLNA to start over on its database.
