MMcD3v1
Jul 01, 2017Tutor
RN 214 OS 6.7.5. DNLA duplicated songs listed on receiver
On my 214 running OS6.7.5 I'm seeing duplicated (actually 3) listings of every song in my music library on my Yamaha receiver running the most recent version of its firmware. The song/files are not du...
MMcD3v1
Jul 04, 2017Tutor
Sorry - what is plex? I don't see it in the app store
- aksJul 04, 2017Virtuoso
I've had funny issues when moving media around, but always been corrected once I did a manual rescan. Could the client/player have cached the listings in some way by chance - have you tried more than one client?
Plex is another media server available from Plex - see details about installing it here.
- StephenBJul 05, 2017Guru - Experienced User
MMcD3v1 wrote:
Sorry - what is plex?A popular media streaming system. Client apps are available for Android and iOS, and several smart TVs. It also can stream to a browser, and via DLNA.
The client apps and web interface can work over the internet, so you can access your media when away from home.
MMcD3v1 wrote:
I don't see it in the app storeIt's not distributed through the app store, you get it from https://www.plex.tv/downloads/
MMcD3v1 wrote:
Could the receivers be caching it?In theory, but I think your testing has already ruled that out.
MMcD3v1 wrote:
Could there be iTunes libraries that are duplicated somewhere that it is pulling from?ReadyDLNA has its own media scanner, so it is not looking at other databases.
MMcD3v1 wrote:
Is there a way to find and erase and DLNA list?I believe disabling the service in system->settings->services will do do that (as will the manual scan control there).
Try removing DLNA from all your shares (from the share list settings), then do a manual rescan. The players should then see an empty list.
Then add DLNA back for one share, and manually scan again. If you see duplicates, at that point, perhaps double-check the share for duplicate copies or perhaps shortcuts.
You could also create a new share, and copy just one or two albums into it. Leave DLNA off on the real share, just enable it on the test share. That might speed troublshooting.
