MMcD3v1
Jul 01, 2017Tutor
RN 214 OS 6.7.5. DNLA duplicated songs listed on receiver
On my 214 running OS6.7.5 I'm seeing duplicated (actually 3) listings of every song in my music library on my Yamaha receiver running the most recent version of its firmware. The song/files are not du...
Jul 10, 2017Guru - Experienced User
aks wrote:
Let's see if StephenB has any progress with checking against his RN214 (I don't have that unit).
Actually I have an RN202 which I tested with - closest thing I have to an RN214. It's running 6.8.0-T54 beta firmware.
Pictures, Music, and Videos were all initially empty. I added three albums to the music folder and three videos to the videos folder, and then did a manual rescan.
I am not seeing any duplicates anywhere using my Samsung SmartTV as the client.
MMcD3v1
Jul 10, 2017Tutor
Ran ;8200 status- shows 6140 audio files, which is probably right. So this number includes the duplicates.
if I turn SSH on ( I found) where do the logs show up in the logs
- StephenBJul 11, 2017Guru - Experienced User
journalctl | grep -i dlna and journalctl | grep -i upnp give some information but nothing about what's in the database.
There used to be a debugging mode available in OS 4 systems - but I don't know how to enable that with OS 6.
- aksJul 11, 2017Virtuoso
I just tried an old VM image (6.4.1) and you can get debug via SSH command line. This shows the file list being scanned.
A quick initial check would be to look at the config file. From a command prompt (via ssh on the ReadyNas):
# cat /etc/minidlna.conf
This will show the directories being scanned. Maybe they are listed more than once?
- StephenBJul 12, 2017Guru - Experienced User
What command did you use?
I agree that would be good to check.
