Learning2NAS's avatar
Nov 23, 2015
RN104 Freezes when doing large transfers via USB 3.0 on 6.4.0
My RN10400 has been working great since purchase. However, I've never transferred over USB extensively; all of the data was loaded over the network. Now I have a large set of folders on a USB 3.0 HDD...
  • guigui_bebert's avatar
    guigui_bebert
    Nov 24, 2015
    Hello,@Learning2NAS
    In my case (erratic freezezs when writing large files on disk).
    An upgrade to 6.4.1 RC1 + Factory reset (AKA factory reset under 6.4.1) solved the issue.
    As a test I did went back from 6.4.1 to 6.4.0 stable (what a joke ;-) ) and it immediatly froze again.
    So if you are up to wipe your NAS, try a factroy reset to 6.4.1 before trying to downgrade.
    Please report the result of this, it would help a lot other contributors
ProSupport for Business
