Starminder
Apr 26, 2019Guide
RN214 Cannot connect
Raidar sees it, but I cannot connect to the admin page through a web browser, connection refused. Apparently pool is offline. I've had a case open for almost a week now with little response :/. Ca...
May 04, 2019Guru - Experienced User
Starminder wrote:
Raidar sees it. but indicates the volume is inactive.
Ok. A reasonable next step is to power down the NAS and test the disks in a Windows PC with vendor tools. That would be Lifeguard for Western Digital and Seatools for Seagate. You can connect either with SATA or via a USB adapter/dock.
Label the disks by slot as you remove them.
Hopchen
May 11, 2019Prodigy
Sorry Starminder
I left you hanging. Had to go inactive for a while. Where did you end up with this?
- StarminderMay 12, 2019Guide
No worries Hopchen . I appreciate your help. I'm still in the same boat.
I tried rebooting to no avail. Cannot see device through admin page. Can see device with Raidar. Per Tier 2 support, booted to Tech Support mode. Case was escalated to Tier 3 over a week ago, have not heard from anyone since.
I guess I can run the tools and test the disks next, I was trying to leave things in place for Netgear Support as they requested.
- HopchenMay 13, 2019Prodigy
Ok, so you opened a case with NTGR. Well, leave the NAS as is (in tech support mode) and wait til L3 takes a look at it :)
- StarminderJul 03, 2019Guide
Hopchen Well, I'm still back where I started, nothing's changed. There's been no activity on my case in almost a month. Is there a way to escalate the case to a supervisor?
Case #41192043
Thanks!
- JohnCM_SJul 03, 2019NETGEAR Employee Retired
Hi Starminder,
I have forwarded this to an appropriate team so they can send a follow up to the L3 handling the case.
- StarminderJul 13, 2019Guide
JohnCM_S Another 10 days have gone by and nothing happened. Can this get reassigned?
- JohnCM_SJul 13, 2019NETGEAR Employee Retired
Hi Starminder,
I have sent another follow up regarding the case. I am not sure why no one has contacted you yet. I will provide you an update once I get feedback.
- JohnCM_SJul 16, 2019NETGEAR Employee Retired
Hi Starminder,
It looks like you are already in contact with L3. You may just update us if you will need again our assistance.
