gpaolo
Nov 26, 2017Luminary
RN314 CPU Temperature
Hi all, I have the feeling that my RN314 has some problem with the CPU heatsink. Temperature is constanly over 65 degrees, with the fan quite noisy. As soon as it does something, the temperature goe...
Nov 28, 2017Guru - Experienced User
I suggest PMing Skywalker since it is a beta unit. My understanding is that beta units are not covered by warranty.
gpaolo
Nov 28, 2017Luminary
Yes, it makes sense to me. I would be surprise if they were covered by warranty.
I will send a message to Skywalker, thank you!
