sevilla315
Aug 12, 2018Aspirant
SMB1/2 access problems
Hi all,
A few months ago I had some problems with the SMB1.0 problem after some Microsoft updates and I found some threads on here advising a few things here : https://community.netgear.com/t5...
bedlam1
Aug 12, 2018Prodigy
Yes it will, just follow the guide here, partcularly the update Bios whilst still running 4.2.xx LINK
Read all posts
Read ALL posts
sevilla315
Many thanks, I've updated the bios, just need to backup all the data onto usb drive, there's > 1TB of data so will take some time.
Cheers,
Steve
- mdgm-ntgrAug 12, 2018NETGEAR Employee Retired
Note that whilst updating the BIOS it is important not to interrupt power to the NAS. It's not essential to update the BIOS on your system and if you have the Pro 6 you should already have the latest BIOS dated 07/26/2010.
The add-on doesn't check to see if you have the latest BIOS already installed.
