ikonuk
Jan 14, 2017Guide
Strange Warning: Less than 5% of volume media's capacity is free.
I got a strange Warning ofrom my RN102 after upgrading to ReadyNAS 6.6.1. "Volume: Less than 5% of volume media's capacity is free." When I browse the sytem via the Web interface I see that I...
- Feb 01, 2017
On another thread, Netgear said they'd be starting a 6.7.0 beta very soon to roll out AV fixes.
Roel1
Mar 04, 2017Apprentice
I am having the same or similar problem:
[17/03/03 09:02:09 WET] warning:volume:LOGMSG_VOLUME_USAGE_NOTICE Less than 30% of volume data's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection snapshots will be deleted when volume free space is less than 5%.
[17/03/03 09:02:40 WET] notice:system:LOGMSG_ANTIVIRUS_DEF_UPDATE Antivirus scanner definition file was updated to 57.23158.
[17/03/03 09:02:29 WET] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[17/03/03 19:57:53 WET] warning:volume:LOGMSG_VOLUME_USAGE_CRITICAL Less than 5% of volume media's capacity is free. Performance on volume media is degraded. To improve performance, you must add capacity.
My ReadyNAS is also a whole lot slower. I will disable the AV to see if it makes a difference.
FramerV
Mar 05, 2017NETGEAR Employee Retired
Hi Roel1,
You could also consider updating to the BETA firmware.
ReadyNASOS 6.7.0-T180 (Beta 3)
- FramerVMar 10, 2017NETGEAR Employee Retired
Hi Roel1,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
