Soccerman18
Sep 01, 2015Aspirant
Stuck on IP 192.168.168.168
I have a ReadyNAS Ultra 4 Plus, after a recent power outage every time the NAS powers up it has the IP of 192.168.168.168. Every other device connected to the router is working correctly. I tried p...
JennC
Sep 02, 2015NETGEAR Employee Retired
Hello Soccerman18,
Try setting up a static IP of 192.168.168.5 on your computer first. Then you shoudl be able to acces sthe admin page of the NAS via hhttp://192.168.168.168. Once logged in, go to Network > Interfaces on the left blue panel. You should be able to see the following:
IP assignment:
IP address:
Netmask:
Set IP assignment to Use Values from DHCP server, then tyoe a valid IP address that is with the same IP range of your router in the IP address field. For example, if the router is 192.168.1.1, you can set a 192.168.1.x where x being any number between 1 and 255 and not being used by any other LAN device on the network, netmask is 255.255.255.0.
Apply the changes, once it took it, you will lose the admin page. Remove the static IP address you have set on the computer, set it to Obtain IP address automatically and Obtain DNS addresses automatically.
Then try to check if you will be able to access the NAS again, this time using the new IP address you have set on the NAS - http:// <new IP address>.
Hope this helps.
Soccerman18
Sep 02, 2015Aspirant
I had only one cable plugged in, tried moving it to the other port but no luck there.
I was able to set it to a static IP and now I'm able to access the drive again. Thanks! I'm curious though, it's been working for years getting its IP from the router, why would that suddenly stop working?
- StephenBSep 03, 2015Guru - Experienced User
Maybe try switching back to dhcp (as Jenn suggested) and see if the problem comes back.
- JennCSep 03, 2015NETGEAR Employee Retired
Hello Soccerman18,
It seems it could not get an IP address from the network.
If you want to troubleshoot further to know what would have caused it, you may try doing soem problem isolation first. Like, if the NAS is connected to a switch (and switch is connected to a router), connect the NAS straight to the router and see if the same problem that it won't acquire a valid IP address from the network.
Please note that 192.168.168.168 is the default IP address of the NAS, if it does get an IP address from the network it automatically uses its default one.
You might also want to check if the firmware of the NAS is updated.
