McGarnagle
Nov 17, 2017Aspirant
TrueCrypt container
Hi I currently store a few TrueCrypt containers on my ReadyNAS 316. I use TryCrypt to mount these containers when i wish to copy/paste additional files into the container. This has always worked f...
- Dec 05, 2017
I have a new local build of the SMB Plus app that adds an option for this setting. Get it from here, and install from the Apps tab, using the Upload button. Then launch the SMB Plus app, go to the Write Options tab, and disable Strict Sync.
We plan to make this a per-share option in a future firmware release.
Nov 20, 2017Guru - Experienced User
Ok. Do you see any speed drops when you access the NAS shares with similar size files?
Also, the PC is connected with gigabit ethernet?
McGarnagle
Nov 20, 2017Aspirant
I would say that i don't see any speed drops for NAS shares with similar size files.
For example, i can create a duplicate 1GB file inside a share by copy/pasting (location of both files is the same. The speed is fine in this case. If i do the same thing to a similar size file already saved in the container the speed drops.
Also, the PC is connected with gigabit.
- StephenBNov 20, 2017Guru - Experienced User
Ok.
I don't use TrueCrypt, so I have no hands-on experience here. The encryption and container management is happening on the PC, the NAS is only supplying block storage (similar to an iSCSI LUN in that respect). One puzzle here is sorting out what the PC overhead actually is. It likely depends on whether the PC supports hardware accelerated encryption (or not).
You could create a TrueCrypt container on the PC, and see what performance that gives you. If you have a second PC, you could try sharing the folder that container is in with Windows Filesharing, and compare that performance with the container on the NAS.
The initial burst of speed at the beginning of the measurement is likely a caching side-effect, your sustained speed is the real speed.
- LucAce01Nov 22, 2017Aspirant
This issue was introduced in ReadyNAS 6.9.0 and is still present in 6.9.1 (Just released). When performing writes to a TrueCrypt container that is on an SMB share with Snapshots off, COW disabled, File search disabled and antivirus disabled the performance drops to very low levels (15Mbit/s) and the HDD is actively thrashing about (a lot of noise due to the drive heads seeking). I reverted to 6.8.1 (while I know is not recommended) and the issue went away. So this is a new issue introduced with 6.9.x. In my case there are no connection or HDD issues, transfers outside of the truecrypt volume appear to be ok. Also it only appears to apply to writes to the truecrypt container as reads, at least my case, appear to be ok.
- McGarnagleNov 24, 2017Aspirant
Thanks LucAce
I was in the middle of doing a systematic test of every hard drive and combination of writing to containers (on and off the NAS). Common denominator was that everytime i'm writing to a container on the NAS the speed is too slow to use. I wonder if this is going to be fixed in a future update? What are the issues in reverting back to 6.8.1?
- SandsharkNov 25, 2017Sensei
I can confirm this behavior, but I can't explain it. I have two Pro2 units, one running OS6.9.1 and the other 6.8.1. but otherwise similarly configured. I created a 200GB static VeraCrypt volume on each NAS in a share where CoW and snapshots are disabled. Veracrypt running in Windows, not on the NAS. I did a Windows drag-n-drop copy of about 40GB of photos and videos in multiple folders/subfolders to each. Time to complete with the Veracrypt volume on OS6.9.1 was 5 hours. Time to complete with Veracrypt volume on 6.8.1 was 21 min. Time to just copy the folder to the share itself with OS6.9.1 was 30 min. All operations used the same PC on a home network with nearly no other traffic.
The PC and NAS CPU and network usage were much higher on the actions that were the fastest, so clearly it is the access to the file itself that's the bottleneck, with it acompinied by a lot of disk "thrashing". SMBD was at 50% for the direct copy, 40% with the Veracrypt volume under 6.8.1, and 3% with the Veracrypt volume under 6.9.1. But nothing else was eating up the CPU.
So, I decided to see what would happen with a static .VHD container under 6.9.1, and the results were similar to the VeraCrypt volume under 6.8.1.
I have no idea what aspect of 6.9.x is causing this, but something sure is different that is used by Veracrypt/Truecrypt but not much or at all with a .VHD container or normal file storage.
- StephenBNov 25, 2017Guru - Experienced User
Perhaps check with ssh to see if the container is fragmented. Maybe also confirm the CoW is really off?
Is the NAS using encrypted SMB3 on the container's share?
The GUI definately says CoW is off. Is there another way to confirm that? Maybe that's the issue, but I would expect that to have similar effects on both container types. No encryption enabled except that Veracrypt is encrypting on the PC before storing.
As for fragmentation, filefrag says the Veracrypt container has 1277 extents and the .VHD has 14212 on the 6.9.1 system.. The Veracrypt one has 796 on the 6.8.1 system and I dind't do a .vhd on it. I find that number of extents on the .vhd very odd, as it was created after the Veracrypt one and there should have been plenty of space to be mostly contiguous.
For my use, I can probably move to .vhdx files (though I didn't check that yet -- only checked .vhd). I have always used TrueCrypt/VeraCrypt ones because they are more robust than .vhd. But .vhdx is supposed to fix that and I no longer have a need to access them from Win7. But for anyone that actually needs encryption or access by something other than Windows 8+, that's not an alternative.
lsattr will tell if it is off for a specific file (the "C" attribute is set if CoW is off - backwards from what you might think).
If it isn't set, try creating a subfolder from ssh, and then set +C on the subfolder with chattr. Then copy the container into the subfolder. C should be set on the copy.
OK, so I created a BitLocker encrypted .vhdx file and it also works without the issue. So for those using Windows 8 or 10, Pro or Enterprise versions only, this is an option. There are not all of the command-line options to do the mounting via a batch file, though, as there are in VeraCrypt.
If you don't need encryption, then you can use lesser versions of Win 8/10. If you need to have access from Win7, you can use a .vhd instead of .vhdx. Win7 Ultimate does support BitLocker, but I don;'t know if it was ever updated to allow for encryption not tied to the computer, as I have never had Ultimate.
My understanding is that Win 8/10 Home can access a BitLocker encrypted drive, just not create one. But what that means if you write to it, I don't really know. I also have no Home versions.
Ideally, though, what causes this needs to be determined and eliminated.
I wonder if Skywalker has anything to say on this.
Just checked, and the "C" attribute is there.
- SkywalkerDec 02, 2017NETGEAR Expert
Yes, the difference is the default sync policy. Every prior version of Samba that we have used ignored sync requests from SMB clients by default. That has changed in Samba 4.7.0, which was included in 6.9.0. See the Samba wiki for details.
You can change that setting manually by running:
# echo strict sync = no >> /etc/frontview/samba/smb.conf.overrides
from an SSH session. I'll see if we can get this option added to the GUI in a future firmware release.
- LucAce01Dec 02, 2017Aspirant
This resolved the issue for me, Thanks.
- McGarnagleDec 04, 2017Aspirant
Hi Skywalker
Is there an easy way to do this? I'm not great at following how to change this setting.
- StephenBDec 04, 2017Guru - Experienced User
McGarnagle wrote:Is there an easy way to do this? I'm not great at following how to change this setting.
He already provided the easiest way.
First enable ssh on your NAS from the web ui (system->settings->services page).
If you have a mac, you can connect to the NAS with terminal. You open terminal, then type ssh root@NAS-IP-ADDRESS. After you enter this, you'll be prompted for a password. Use the NAS admin password.
If you have a windows PC, then download putty from here: https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html. Access the NAS with putty (selecting ssh). Use root as the username, and the NAS admin password.
After you log into the linux shell successfully, enter the command that skywalker gave you at the # prompt.
- SkywalkerDec 05, 2017NETGEAR Expert
- SandsharkDec 05, 2017Sensei
Skywalker wrote:We plan to make this a per-share option in a future firmware release.
Great! That'll give mne the best of both worlds. I can disable it for my backups share and enable it everywhere else. I'm still going to see if the IDRIX folks can do something about it in VeraCrypt..
- McGarnagleDec 06, 2017Aspirant
Unfortunetely this does not work for me. I installed the SMB Plus app and ensured the Strict Sync was disabled (it was already set to disabled before i checked). Then i reset the NAS.
However, the original problem has not changed. Is there something that i could be missing? - SkywalkerDec 08, 2017NETGEAR Expert
It doesn't make sense that Strict Sync would have already been set to disabled, unless you ran the command I posted earlier from a terminal. Maybe there's some strange browser issue with the SMB Plus app? In any case, I can take a look to confirm that the proper setting is in place if you enable Secure Diagnostic Mode and PM me the 5-digit number.
- McGarnagleDec 08, 2017Aspirant
Hi SkyWalker
I did a little more checking. It appears that the problem only persists for TrueCrypt 7.1a containers. VeryCrypt containers seem to work ok. I don't know if this makes sense but its probably good enough for me since i can simply make VeryCrypt containers and move everything there.
Actually, spoke too soon. I was looking at the wrnog thing. Looks like the problem persists for all containers. SkyWalker ive PM'd you the 5 didgit code as suggested.
The strict sync setting looks good, but I see you've got the max protocol set to SMB1. SMB3 is much more efficient. Can you switch to that and then try some SMB transfers? I can monitor the system operations during the transfer to see where the bottleneck is.
